Brave does not block Redirects Even after turning on Aggressive Blocking
For the past 1 month I’ve been usong brave browser . It was working perfectly fine until today It started redirecting me to random websites as soon as I was clicking anywhere on the website https://movielair.cc/ .IT was working fine when I was previously watching movies on it . Suddenly today , it started to redirect me.
Even after changing the settings to “Aggressively Block trackers and ads” , it is not blocking the redirects .
**Did the issue present with default Shields settings? (yes/no)**Yes
**Does the site function as expected when Shields are turned off?**No
**Does the ad appear when using a Private window as well? (yes/no)**Yes
What OS are you using when you see the ad? Windows 10 64 bit
Brave version (check About Brave): Brave 1.80.115 (Official Build) (64-bit)
Even with Aggressive Blocking on, some redirects still slip through. Use extra tools like uBlock Origin or custom filters for better control.
How can I do that ??
