Brave crashing when trying to work on it
  • Brave closes itself after trying to do the following:
    Searching anything on the task bar
  • trying to access brave settings like history, settings, tools etc.
  • trying to install brave or import settings/bookmarks
In my case, this happened for no aparent reason.
  1. I first started my pc like always, no problems, no issues.
  2. I started brave for the first time in today’s session, then noticed how it just, shut off on me.
  3. Tried opening brave in administrator mode, didn’t work.
  4. Tried opening brave in incognito/guest, DID work!
    1. But ONLY WORKED within the same page, if I tried searching for something, like a link or a normal google search, it would immediately crash.
    2. Some parts of the configuration do not crash on me, like the main panel for configs, but thats it, if I accessed further, it would crash.
  5. Deleted cache and remade User Data folder, as well as disabling GPU. Nothing.
  6. Installed newest graphic drivers, nothing.
Every time I tried searching on the internet, it would load it up for a bit, before just crashing the app.
I have never encountered this issue before, everytime before this session, brave would normally launch, and let me do whatever I wanted with it. Today is the only day it started happening.
Windows 11 home version 25H2, within an MSI Thin GF63 12VE. Brave version 1.88.130
Just to resume everything, brave opens fine unless I try loading a website or search for anything. As well as trying to access brave settings, tools or configuration.
This only happens with brave, any other browser works just fine.
New update: If I click links from other browsers or text chats, brave loads the page correctly without crashing. It only crashes if I do things inside brave itself.
CASE SOLVED!
It seemed a recent update from an extension (Tampermonkey) broke a bunch of code or replicated code needed for Brave to function correctly, crashing the browser altogether.
THOSE WHO HAVE MY PROBLEM, MAKE SURE TO DELETE YOUR EXTENSIONS ONE BY ONE!
