Brave crashing out of thin air
Brave keeps crashing with no apparent reason.
V1.39.122
It started happening around June 2nd and since then my browser keeps crashing multiple times per day even when I wont use it and its just open in the background.
Uploaded Crash Report ID’s:
Crashes from June 11:
4a450200-b1ec-5608-0000-000000000000
ad3c0200-b1ec-5608-0000-000000000000
66920200-b1ec-5608-0000-000000000000
Crashes from June 10:
93400200-b1ec-5608-0000-000000000000
92400200-b1ec-5608-0000-000000000000
8f400200-b1ec-5608-0000-000000000000
Is this Windows 10? If you run winver what version of Windows 10 does it show? (e.g., 1909, 20H2, etc.)
Do you get any error messages?
Is any antivirus or other security software installed?
Do you have any extensions installed/enabled? If so, does it still happen with them all disabled?
Is anything set in brave://flags ? (Anything with a non-default setting will be sorted to the top, and will have a blue dot next to it.)
I’m on Win 11 Version 21H2.
None it just closes without any message.
Yes but it even happens with them turned off.
Yes I do and it still happens with them disabled.
No I haven’t set anything in there.
