Brave Crashing on Startup (maybe new extension problem)
  1. I try to open Brave and it closes after a few seconds.
  2. This has been happening since today. Last night everything was normal.
  3. I installed two extensions yesterday: blackbox and a google translator extension.
103.1.41.96 (not sure if it is the right answer)
I’m not sure if the problem is with the new extensions, but that was the only browser modification before the error. If there was a way to uninstall extensions, I’d like to try it.
I wouldn’t want to go out and try out every possible solution that has already been available on the forum because I’m afraid of screwing up something other than the problem. Is there any way to send a crash file?
I would have no problem uninstalling all of Brave and reinstalling, I just can’t lose the passwords I have stored and I wouldn’t want to lose my bookmarks.
I installed an older version, which doesn’t sync, and it stopped closing unexpectedly. I took the opportunity to uninstall both extensions. The problem is that the browser automatically refreshes and has the same problem again - it looks like the problem wasn’t the extensions.
I also tried to open the browser in private mode, but it doesn’t even open when I choose that option.
I apologize in advance, I’m not an expert in the field and I’m also a little old.
Thank you very much.
@vini76
Re Brave version numbers (example from my Mac, July 20, 2022):
Screen Shot 2022-07-20 at 5.37.58 PM
Re Testing Extensions
Study:
64 architecture
  • "C:\Program Files\BraveSoftware\Brave-Browser\Application\brave.exe" --disable-extensions
x86 architecture
  • "C:\Program Files(x86)\BraveSoftware\Brave-Browser\Application\brave.exe" --disable-extensions
When you get Brave Browser started, then Disable and Remove the two Extensions that you mentioned. Exit / Quit Brave Browser.
Restore the Windows shortcut for Brave Browser . . .
64 architecture
x86 architecture
Start Brave Browser.
Test each of the Extensions, alone, one-at-a-time.
Re Sending Crash Reports
Re Backup / Save Passwords
https://community.brave.app/search?q=passwords%20csv%20%40CerealLover%20order%3Alatest
Re Latest Brave Browser Stable Release
‘https://github.com/brave/brave-browser/blob/master/CHANGELOG_DESKTOP.md’
Thank you very much for your time!
I did everything that was said to be done, but to no avail.
When I was able to install the old version, before it was automatically updated to the latest version, I was able to uninstall the extensions. The issue has not been resolved, which seems to indicate that the extensions are not causing the browser to close unexpectedly.
Likewise, I opened the browser via command line, with all extensions disabled, as described, but with no result.
I was able to quickly go to brave://crashes in the few seconds the browser stays open, but I couldn’t get any results when I clicked submit because the browser immediately closes, without being able to receive the diagnostic reports.
@vini76
Copy the Bookmarks files to a safe location on your computer, beyond/outside the Brave Browser installation paths.
Bookmarks and Bookmarks.bak files:
  • %LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Bookmarks
  • %LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Bookmarks.bak
Delete the ‘Caches’ folder, and delete the ‘Cookies’ file.
Caches (folder):
  • %LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Cache\
Cookies (file):
  • %LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Cookies
Your: ‘opened the browser via command line, with all extensions disabled, as described, but with no result’
I am uncertain about the trailing part: ‘but with no result’ . . . means?
For the following, add the switches to the Brave Browser shortcut.
The switches (that will follow) are intended to:
  • start up Brave Browser, showing a New Private Window
  • disable all experiments at brave://flags
  • disable extensions
  • disable GPU ie disable Hardware Acceleration
  • enable leak detection and if that failure occurs, then crash the browser (–enable-leak-detection --crash-on-failure are a combo)
  • produce error/log output to a file named ‘brave_console_out.txt’ on the Windows OS Desktop
64 architecture (note the switches to add):
"C:\Program Files\BraveSoftware\Brave-Browser\Application\brave.exe" --incognito --no-experiments --disable-extensions --disable-gpu --enable-leak-detection --crash-on-failure 2> %USERPROFILE%\Desktop\brave_console_out.txt
x86 architecture (note the switches to add):
"C:\Program Files(x86)\BraveSoftware\Brave-Browser\Application\brave.exe" --incognito --no-experiments --disable-extensions --disable-gpu --enable-leak-detection --crash-on-failure 2> %USERPROFILE%\Desktop\brave_console_out.txt
You would add the following, in the Brave Browser shortcut:
  • --incognito --no-experiments --disable-extensions --disable-gpu --enable-leak-detection --crash-on-failure 2> %USERPROFILE%\Desktop\brave_console_out.txt
Add those to the end of the Target field’s existing string.
Start Brave Browser via the Brave Browser shortcut.
IF Brave Browser keeps running . . .
Go to: brave://flags and click the ‘Reset all’ button. Relaunch Brave Browser.
Take a look at the ‘brave_console_out.txt’ file (if it exists), on the Desktop.
In the Brave Browser shortcut, remove the --no-experiments switch.
Try brave://crashes effort, again.
When you think appropriate, restore the Windows shortcut for Brave Browser . . .
64 architecture
x86 architecture
“Bookmarks and Bookmarks.bak files:”
-There’s no Default\Bookmarks.bak, only Default\Bookmarks
“Delete the ‘Caches’ folder, and delete the ‘Cookies’ file.”
-There’s no Cookies file.
“Your: ‘opened the browser via command line, with all extensions disabled, as described, but with no result’
I am uncertain about the trailing part: ‘but with no result’ . . . means?”
-Sorry, I meant the browser keep closing unexpectedly after few seconds.
“Take a look at the ‘brave_console_out.txt’ file (if it exists), on the Desktop.”
-There’s no ‘brave_console_out.txt’ file on the Desktop (or anywhere else on the computer).
“Try brave://crashes effort, again.”
-Now I saw that the Crashes Report was sent yesterday.
-The crash report ID is: f6d30800-2312-8508-0000-000000000000
-I just restored the Windows shortcut for Brave Browser to test if the issue is resolved, but it keeps closing unexpectedly after a few seconds.
Thank you again.
