Brave converts http to https where there is not certificate
I have a server hosting several sites. Some of the sites I can access with http://xxx.yyy.info with not problems. Other sites when accessed with http://zzz.yyyy.info the browser changes to https (443) and of course the server does not answer. I have performed a capture on the server looking for port 80, and when going the http://zzz.yyyy.info, the server is never contacted on port 80. Yet, when changing the capture to port 443, the server answers, but rejects.
just try to access http://zzz.yyyy.info
every time.
windows 10
Brave [Version 1.17.73 Chromium: 87.0.4280.67 (Official Build) (64-bit)
Go to the settings, Shields, then find “Upgrade connections to HTTPS” turn that off, and you get your expected result. It’s not a bug.
