Brave closing randomly without interacting
I use Brave and often am watching a youtube video, and the browser randomly shuts down without any interaction.
Not crashing randomly
Version 1.21.76 Chromium: 89.0.4389.86 (Official Build) (64-bit)
Any help appreciated! No idea how to try to fix this
Hi @ninjagaijin, Welcome to Community!
Do you have any extensions installed? If so can you try disabling/uninstalling them?
Also, can you try disabling Hardware Acceleration in settings to see if this resolves the issue?
You’ll find this in Settings --> Additional Settings --> System --> Hardware Acceleration
Thanks for the reply Aa-ron, trying that now to see if it helps!
Is there any log file I should search for, to try to attain a cause of the crashes?
