I did download the installer for Brave and it did stay open longer, however, usually after about 30 min to 1 hour it would crash again. The Beta Brave stays up. Cyn
Yes I have been trying this daily, to download and then leave it open to see if it crashes. It always does, sometimes faster than others. Any new thoughts? Cyn
I asked Perplexity.ai to decipher those commands. The reply:
Those three commands are working together to take control of the Brave Browser profile folders and reset their permissions for the Administrators group.
1) takeown /F ... /R /D Y /A
takeown /F C:\Users\USERNAME\AppData\Local\BraveSoftware\Brave-Browser /R /D Y /A
takeown – changes the owner of files/folders.
/F <path> – target folder: here it is the Brave-Browser folder in your profile.
/R – recurse into all subfolders and files.
/D Y – automatically answer “Yes” to any confirmation prompts when access is denied.
/A – make the Administrators group the owner (instead of just the current user).
Effect: Administrators become the owner of the entire Brave-Browser tree under that user profile, including all subfolders and files.
/setowner Administrators – explicitly sets the owner to the Administrators group.
/T – applies to the folder and all subfolders and files.
Effect: Confirms and enforces that Administrators are the owner of everything under Brave-Browser (similar goal to the first command, using a different tool).
/inheritance:e – enables permission inheritance so items inherit ACLs from their parent folder.
/T – recurse through all subfolders and files under BraveSoftware.
/C – continue even if errors occur (skips over problem files, keeps going).
Effect: Re-enables normal inherited permissions for everything under BraveSoftware, so permissions flow down from the parent instead of using only custom/blocked ACLs.
Overall purpose
Together, these commands:
Make the Administrators group the owner of the Brave Browser data folder and all of its contents.
Ensure that ownership is set consistently using both tools (takeown and icacls).
Turn inheritance back on for the broader BraveSoftware folder so its permissions are normalized and inherited from its parent, which can fix “Access denied” and permission corruption issues within the Brave profile.
I went back and just put in cyntexas and it allowed me to change the owner!! I was trying to type it all! and didn’t need to! Thank you so much for this help! However, it only stayed open about 3 minutes before it slammed shut and crashed! I will try restarting my laptop to see if that makes a difference, it didn’t. I restarted and it went down very quickly! So I do not think this helped at all.
Next do I try to do the “takedown” list? The previous file and folder permissions changed the owner to me, cyntexas. It looks like this is changing these two, “takedown” and “icacls” back to Administrators? I am not this advanced and just want to make sure I am not going to mess up the laptop?
289wk
Can you tell me what to do next? Now that I have sent you the Profile Path?
I have yet to do the “takedown” and “icacls” would that be next? I want to be sure to do this all in the correct order.
Thank you for your help. Cyn
You lost me back at your post where you began: “I went back and just put in cyntexas …”
And, I do not understand your replies that you make via e-mail.
I am uncertain about being able to help you. If you have questions about the details of examining / fixing permissions, I suggest that you consult with ChatGPT.
@CynTexas can you please launch the browser and then - quickly - go to brave://crashes and grab the last three or so crash report IDs you find here with me? They should look something like this:
Sorry – I’m not super clear what you mean by this, can you elaborate?
Additionally, it looks like your crash reports are not uploaded, meaning that the crash report IDs have not been generated. Please visit brave://crashes again and click Send now to upload the most recent reports (lets say last 3):
When you do, the entry will show Status: Uploaded and there will be an Uploaded Crash Report ID listed below that. Please copy/paste/share those IDs with me here.
By the way, this morning I did the takeown and the icacls and the inheritance all three ! They said they worked.
@CynTexas those local crash contexts still aren’t uploaded – if they’re uploaded properly, they should all end in 0’s as shown in my screenshot. Can you please ensure that you’ve cilcked Send now under the individual crash entries?
