Brave Cardano token and wallet blockchain project
Has the Brave developers considered creating a Bat token and browser wallet on the Cardano blockchain?
What’s the advantage? Creating another token will only decrease its value as supply increases.
Imho the way forward is by using layer 2 solutions to extend the existing token to other blockchains.
(What’s the advantage?) Some of the possible advantages.
Improved utility, efficiency and increased quality for user experience. The more versions and interface ideas Brave BAT has for users, the better.
(Creating another token will only decrease its value as supply increases.)
Ok. How about a Brave cross chain bridge to Cardano, and the other blockchains?
(Imho the way forward is by using layer 2 solutions to extend the existing token to other blockchains.)
Presently and moving forward in day-to-day life. What is the use case and usability, benefit of holding or swapping BAT?
And you believe that Cardano will change anything? Can you give some example of any project that suddenly became useful just by moving to Cardano?
I agree with you regarding bridges to other blockchains. But this was not what you proposed in your initial post. You were proposing creating a new token in Cardano.
(And you believe that Cardano will change anything?) I believe there is good potential to gain additional user adoption, rewards and use cases for BAT on the Cardano blockchain.
(Can you give some example of any project that suddenly became useful just by moving to Cardano?)
Suddenly is not the word I would use and one project is SingularityNET.
SingularityNET transitioned to Cardano and still available on the Ethereum blockchain.
(You were proposing creating a new token in Cardano.)
After bridging a coin or token to Cardano. A Cardano native token will have to be created to function in the ecosystem.
It would be very enriching if Brave added Cardano support
It would be enriching indeed to have a BAT - Cardano native token partnership. However, in my opinion. With the Ethereum ecosystem, heretics and the high level of toxicity toward anything Cardano at the moment. Don’t hold your breath.
The Sappy seals are launching Lil Sappys on Cardano very soon. A very successful ETH project sees the value. Also you must not know about the community you will have access to and gain. Midnight will be the first major L2 and cross chain compatible so you would get that as well
Cardano Community is frequently overlooked, but the online presence on Elons app show the sheer numbers of retail users that follow Cardano. Id say the app is dominated by Cardano users, as Crypto polls suggest.
