Brave browser wont relaunch after closing it and opening it again
Hello im having an issue with the browser.
Once i close it down, and open i open it again it wont work. I need to close it in task manager for it too launch. whats the issue?
Hello @canaanite
when you close for the first time does it still show up in the task manager or not
yes it does…
then go to
brave://settings/system
disable hardware acceleration and see if
disable this -> Continue running background apps when Brave is closed make difference
thank you very much, it worked
@canaanite you very welcome
Actually, the problem came back, it doesn not help anymore
