**Description of the issue: Brave Browser will not launch on Windows 11. **
I try to launch the browser, and it will not launch.
*Expected result:Browser launches.
Brave Version( check About Brave):134.1.76.74 presumably
**Additional Information: I have completely uninstalled Brave, including with Revo Uninstaller, deleting all folders and registry keys. I backed up user_Data to my desktop, hopefully I can recover my bookmarks.
I have rebooted several times, including after reinstalling and after install of the latest version from https://brave.com/download/
I click the desktop shortcut, the executable directly from the folder, everything, but it will not launch.
I am running W11 23H2, 22635.4440 , Windows Feature Experience Pack 1000.22700.1055.0
i7-12700k, 32 GB RAM, 64-bit operating system, x64-based processor
Brave is installed on C: drive
Nothing has changed in my environment that I can think of, before this started occuring. **
289wk
March 18, 2025, 8:47am
2
You might verify the installation
Brave Browser installation location on Windows OS
Application “brave.exe”
64 architecture
C:\Program Files\BraveSoftware\Brave-Browser\Application\brave.exe
The initial Brave Browser Profile is, by default, named “Profile 1” (unless you change that name → brave://settings/getStarted).
The folder that contains the initial Brave Browser Profile, is the Default folder (a name that you must not change):
C:\Users[UserName]\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default \
That path may also be written:
%LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default \
%USERPROFILE%\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default \
If you create 1 additional Profile (aka “Profile 2”), it will be stored in folder Profile 1 :
C:\Users[UserName]\AppData\Local\BraveSoftware\Brave-Browser\User Data\Profile 1 \
If you create a 2nd additional Profile (aka “Profile 3”), it will be stored in folder Profile 2 :
C:\Users[UserName]\AppData\Local\BraveSoftware\Brave-Browser\User Data\Profile 2 \
IMPORTANT - Replacing Profile folders
When replacing Brave Browser Profile folders:
Folder named Default (including its contents) can only replace its likeness: the folder named Default .
Folder named Profile 1 (including its contents) can only replace its likeness: the folder named Profile 1 .
Folder named Profile 2 (including its contents) can only replace its likeness: the folder named Profile 2 .
IMPORTANT - Brave Browser Preferences
Some Brave Browser Preferences are stored in the Preferences file:
%LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Preferences
The contents of that Preferences file, are not exactly the contents of, brave://prefs-internals/.
Some Brave Browser Preferences are stored in the Local State file:
%LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Local State
Bookmarks and Bookmarks.bak files:
%LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Bookmarks
%LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Bookmarks.bak
Cache (folder):
%LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Cache\
Cookies (file):
%LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\Cookies
History (file - usually lots of data):
%LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\History
Crash Reports:
%LOCALAPPDATA%\BraveSoftware\CrashReports\
Brave Browser installers are available at:
https://github.com/brave/brave-browser/blob/master/CHANGELOG_DESKTOP.md
