Brave Browser Error: We've detected a problem with your cookie settings
I’ve adjusted plenty of settings but I still receive the following message when attempting add a calendar event and authenticating to Google calendar.
Enable cookies
Make sure your cookies are enabled. To enable cookies, follow these browser-specific instructions.
Clear cache and cookies
If you have cookies enabled but are still having trouble, clear your browser’s cache and cookies.
Adjust your privacy settings
If clearing your cache and cookies doesn’t resolve the problem, try adjusting your browser’s privacy settings. If your settings are on high, manually add www.google.com to your list of allowed sites. Learn more
brave2
Z_https://www.google.com/calendar/render?action=TEMPLATE&text=60+Minute+Consulting+Call****AGoogle&sf=true&output=xml
Redirects to: https://accounts.google.com/CookieMismatch
it should load my Google Calendar
Every time
W10 Brave 64
  1. Try adding “www.google.com” specifically to your “Allow” list. You currently have only google.com. COMPLETE
  2. Try logging out, clearing all cookies and cache, then logging back in and trying it again. COMPLETE
  3. Disabling shield COMPLETE
Same issue
@mantic,
You may have to clear cache/data for accounts.google.com and/or calendar.google.com.
Clear cache with the browser has been done numerous times or are you referring to something else? Can you provide steps?
@mantic,
You’ve cleared all browsing data from your history?
Yes, I’ve cleared all browsing data.
I am having the same issue.
Currently having the same issue
Fixed (maybe temporarily)
I had two profiles setup on my Brave Browser (Personal and Work). I had to clear all data (all time) in both the profiles to get it working again. If you have multiple profiles then do try this out.
Just don’t do the basic clearing, go to the advanced tab and check everything (except passwords if you want to retain saved passwords).
