Brave Android 16 battery drain when using
Hi!
I’m using Brave 1.83.120 on Pixel 10 Pro, Android 16. Sync enabled between my phone and Windows PC. When using browser, I’ve noticed that battery drains a lot, Brave is in the top of highest % of battery usage. I checked also Firefox, to compare and currently battery stats are as follows:
Firefox
App usage time: 1h18min
Background usage: less than 1min
TOTAL BATTERY USE: 13%
Brave:
App usage time: 22min
Background usage: 1min
TOTAL BATTERY USE: 10%
I was using Firefox over 3 times longer than Brave and it used 3% more battery and if I recall, when usage times for these two apps were similar, Brave had something like 10-15% while Firefox was on 5-7%.
I don’t think that is a normal behavior. I’m not keeping opened tabs when closing Brave and I haven’t changed too much settings compared to default and I have no idea what might be causing this drain with Brave.
Thanks for every response :slight_smile:
I am having the same issue I always used brave before because it had great screen on time but its sucking the battery now.
Brave Version: 1.84.136 Android version 15
Sync on. It seems to get randomly warm when brave is open barely doing anything. That never happened before.
I’ll try Firefox for now hopefully others notice and report.
May interest - iPhone test of different Internet browsers’ battery usage:
https://www.makeuseof.com/iphone-browser-battery-test/
