NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
I Used Brave On My Windows Device Previously, After That I Started Using It On My Android Device Aswell, I Synced My Device With Windows, But After A While I Had To Reset My Windows Device For Confidential Reasons, After I Resetted My Device, I Installed Brave But Obviously My Bookmarks Werent On My Windows Device, But They Were On My Android Device, I Thought If I Synced It With My Android Device My Windows Brave Would Be Back To Normal But I Was Mistaken, All It Did Was Add The New Bookmarks To My Android Device.
- Install Brave On Pc And Android
- Sync Both Of Them
- Delete Brave On Windows (wipe data)
- Reinstall On Windows
- Add A Few New Bookmarks On Windows
- Sync Again
- Old Bookmarks From Android Wont Be On New Windows Device
Permanent
Brave Version(See theAbout Bravepage in the main menu):
v1.68.141
Android And Windows
Looking For Solutions.
