Hello, I use Brave since 2019 on Debian 9 and 10 Buster.
Since one week, I have trouble with Binance, Okex and the TradingView Chart.
On Binance the classical Chart show me “chart went wrong” when I change the timeline.
If I want to view the TradingView chart the 3 vertical yellow Binance lines turn and nothing apear.
The chart is not loading.
I tried to clear the cache, shutdown the shield and uninstall/reinstall Brave but the problem persist.
I don’t find any answer from past topics.
On Okex the Trading view chart is working but I can’t change through different crypto. The same Chart stay even after hardrefresh…
Thank you for your help
Binance chart went wrong
- login to binance and open pro chart like https://www.binance.com/fr/trade/pro/BTC_USDT
- Try the “Trading View” (First it open without problem)
- Navigate through the Markets in order to change for ETH or any crypto
After some navigation between different crypto and timeline the TradinView chart is not loading anymore.
So I used the classical Binance Chart but after some navigation with Timeline I get the error message “chart went wrong”
So I can’t use anymore Binance with Brave…
Brave Version( check About Brave):* Version 1.10.93 Chromium: 83.0.4103.106 (Official Build) (64-bit)
Debian 9 stretch and Debian 10 Buster
