Bet365 web page not loading
Hi, when I try go to access bet365 it only displays the loading circle and doesn’t change.
I’ve tried disabling the shield, adblocker and uninstall and reinstall app and nothing has fixed it.
Any help would be appreciated
@Banxed try clearing all cookies. I know I just tested and nothing on Shields seemed to make a difference. Then I opened in a private window and it loaded perfectly fine. After that, I did a second profile and it all worked just fine.
I already have cookies blocked and in private mode by default.
How do I create a 2nd profile on mobile?
@Banxed,
If you’re blocking all cookies, this very the reason that the site isn’t loading. Just tested on my end on Android and if I set cookie controls to Block all cookies, I see the infinitely spinning circle. You need to change it to “block 3p cookies” instead.
