Bat's not showing up in Brave Rewards
Briefly describe your issue:
My BAT’s don’t show up in the Brave rewards section but however if I go to the ads section they do show up.
Android, Brave 1.26.76
Yes
July 13, 2021
No
Are you using a VPN? (yes/no)
No
Yes
Yes
Yes
Can you insert both the Screenshots of your Rewards Section and the Ads Section?
I want to see what they both are showing.
@Sejan,
This is the expected behavior – once you have received your payout for the month, then the number your referring to will increase. It displays the total amount of BAT in your browser wallet – so far it appears that you have not received a payout yet, which means there is still 0 BAT in your wallet.
The BATs gets transferred to this once every Month as Mattches said.
Usually during the First 10 days of the Month.
If you see the third picture, it Says “Payment Date: Aug 8”
So the BAT from there will get transferred to the Picture I attached. Which then can be redeemed into an Uphold Account.
