Hi!
I use Brave regularly and I always click on the notifications I get, but…
The BAT total has been at a standstill for days.
Can anyone tell me what’s happening?
Thanks
Hello @Giovanni_T
you get paid on monthly basis
please check the Estimated pending rewards bats and see if it increase when you got ads or not
There are some problem because, as you can see, the BAT aren’t accumulated…
Appears always and only “no activity this month”…
when did you first enabled the reward option?
In December I enabled it
could you scroll down and see if there any estimated bat there ?
Nothing at all:
I also noticed that if I click on the arrow the window expands but if I click again it does not close again. The same thing happens if I activate the rewards and then I want to deactivate them.
However in the settings I see:
your last image show that there 0.140 bat pending and will be paid for you on arround 6 march
But why in the popup appears “no activity this month" ?
it will show up when you get paid or tipped someone
Another thing:
81 announcements received this month and only 0.140 BAT pending?
first make sure you have the latest version of brave then keep monitor those estimate and when you get ads check if the ads counter and the estimated bat increased or not
if it stuck let me know so to mention some one from the team to check that
