Briefly describe your issue: BAT was withdrawn from my Uphold account without approval. I have auto-contribution off. But this shouldn’t matter since the BAT was in my Uphold account from successful deposits in October and November. It was removed Dec 10th. Where can I privately send the screenshots to Brave support for help? Thank you.
What Operating System and Brave version are you using (Menu --> About Brave)? android 9
Is your browser wallet currently verified? (yes/no) yes
What date did you verify your wallet? 10/20/2021
Have you been able to successfully receive payments in the past? Yes
Are you in a supported region (see here for list of supported regions)? Yes
Does your device pass the SafteyNet check (Android only)? yes
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? Yes
