Briefly describe your issue:
I had already verified my wallet and connected it to Brave on my laptop. I had been using Brave Beta on android in the past but couldn’t connect to uphold before as it wouldn’t let me unless I reached a certain amount. Now I just checked and it allowed me to log in to my existing account, but after doing that, I did not receive the entire amount of BAT I had on Brave Beta.
I only received 3.50 BAT from Brave Beta on android sent to my uphold, when I had 18.750 BAT on Brave Beta on android before connecting.
I was also using Brave Nightly, and I switched to using that from Brave Beta, and so now I am afraid to connect that to uphold as it seems it will cause me to lose the BAT I have on there as well.
Android 11, Build/RPA.200720.012
Brave Beta 1.34.64, Chromium 96.0.4664.110
Yes
Apr 07, 2021
Yes, from desktop Brave.
Are you using a VPN? (yes/no)
No
Yes
Yes
Yes
