Briefly describe your issue:
Since around november on my phone its been showing an estimated amount to payout, at the time I think it was about 8 bat or so ready to go, but I only got about 5 or 6 with around 2 remaining
I assumed that the last 2.odd would just roll over to the next month but several months later its just stuck there as my estimate.
every month since then I have recieved rewards in amounts around 0.3 - 0.6 which is inline with the amount of ads i have recieved, and it has payed out them amounts, but not the other “locked” amount
What Operating System and Brave version are you using (Menu --> About Brave
Android 12
1.49.132
Is your Brave Rewards Profile currently verified? (yes/no)
yes
unsure, have had to connect and reconnet a few times. account has been active as early as possible though
yes
Are you using a VPN? (yes/no)
no
yes UK
unable to install on my device (us only?)
Have you manually turned off Auto-contribute on all of your devices?
yes
