BAT balance went to 0 after tipping (Forwarding issue from GitHub repo)
Hi @RickSayd,
Thanks for writing in! What OS and Brave version are you using? Do you have Auto-Contribute turned off?
Thanks in advance!
I was on macOS and using Brave 0.70.122 (Official Build) (64-bit)
Brave 0.70.122 Chromium: 78.0.3904.87 (Official Build) (64-bit)
Revision 20c21f4010010f32462ea8e1d6af30cef66d48c8-refs/branch-heads/3904@{#840}
OS macOS Version 10.14.6 (Build 18G103)
JavaScript V8 7.8.279.19
Flash (Disabled)
User Agent Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.87 Safari/537.36
Command Line /Applications/Brave Browser.app/Contents/MacOS/Brave Browser --enable-dom-distiller --disable-domain-reliability --no-pings --extension-content-verification=enforce_strict --extensions-install-verification=enforce --sync-url=https://no-thanks.invalid --enable-features=NewExtensionUpdaterService,PasswordImport,WebUIDarkMode,SimplifyHttpsIndicator --disable-features=AutofillServerCommunication,LookalikeUrlNavigationSuggestionsUI,SyncUSSBookmarks,NotificationTriggers,AudioServiceOutOfProcess,SmsReceiver,UnifiedConsent --flag-switches-begin --flag-switches-end
Executable Path /Applications/Brave Browser.app/Contents/MacOS/Brave Browser
Profile Path /Users/antonguy/Library/Application Support/BraveSoftware/Brave-Browser/Default
Also, no I do not have auto-contribute on. I have not touched that feature other than toggling it off.
