avg and avast etc do not allow brave browser
server certificate expired
good luck fellow sufferers.
can you recommend a good browser- that actually works
thanks all
thanks all
You already tried to go www.brave.com instead of p3a.brave.com?
Good luck with your search for a browser xD…
please explain your reply.
the p3a led to
Forbidden
Details: cache-sea4454-SEA 1639860658 2032056653
Varnish cache server
That website is not the official source, please always remember to verify domains
here is the official brave download
i downloaded it direct from the correct source
Brave is up to date
Version 1.33.106 Chromium: 96.0.4664.110 (Official Build) (64-bit)
i use it on a win7 laptop
p3a.brave.com cert is fine. https://www.ssllabs.com/ssltest/analyze.html?d=p3a.brave.com
I would report to AVG/Avast support.
each will point fingers at each other.
thanks
