I recently updated my Mac, and now Brave isn’t autofilling passwords anymore.
They are still saved and stored properly and I have autofill enabled, but they are not being suggested/filled.
I even tried uninstalling and reinstalling the browser based on similar posts, but that didn’t help either. Any suggestions? Is there a new setting in the MacOS to change? I searched but found nothing.
Hello @PhilFry, thank you for bringing this to our attention, can you share a screenshot? Please follow the instructions below:
- Launch Brave
- Open the Main Menu
in the the top right.
- Click
Settings --> Additional Settings --> Auto-fill --> Passwords
Make sure these options are ON > Offer to save passwords / Auto Sign-in
Hope it helps. Regards.
It does function in some tabs now, still not all of them. And it has a 0% success rate in pop up windows, which is one of my main uses for them.
I have the same problem for 2 weeks, the support here is not the best and I have not found a solution, I have installed again and the problem is the same.
