Auto-Contribute turned itself on and donated my BAT
Briefly describe your issue:
When I initially signed up I had turned off auto contribute. When I checked the brave rewards symbol in the search bar today, it said my contributions were taken 2 days ago but that pop-up did not appear in the past 2 days, only when I opened Brave today. It took me to the page with auto-contribute but now it was turned on instead of off like it was originally and it had donated 2/3 of my total BAT.
Windows 10.
Version 1.35.103 Chromium: 98.0.4758.102 (Official Build) (64-bit)
Yes
Today (2/21/2022)
Yes
Are you using a VPN? (yes/no)
No
Yes
N/A
Yes that I am aware of.
Thanks for reporting. I’d like to ask a few questions to start:
  • Auto Contribute is ON by default and must be manually turned OFF. Did you turn it OFF?
  • Do you have multiple devices linked to your Uphold? If so, is Auto Contribute turned OFF on each of these devices?
  • Can you share a screenshot of your Contributions and Event Log tabs which can be found here brave://rewards-internals/
Thank you in advance!
