Asunnot.oikotie.fi first party ad | Brave aggressive
First party ad showing with brave aggressive blocking
yes
yes
Does the ad appear when using a Private window as well? (yes/no)
yes
What OS are you using when you see the ad?
Win 11
v1.80.115
Any fixes will come from the Regional Finnish list, brave://settings/shields/filters
Ensure that is enabled
I think it’s self-promo and should not be blocked. The same corporation (Vend) owns both of those services
From maintainer.
Add this too you personal list; asunnot.oikotie.fi##.padded--desktop-v50-h0
But braves Aggressive filtering should block first party ads?
Only if the site is in the list, if it isn’t. Then you need to manually added it. Adblockers in general behave like this
