Anyone have a solution for stuttering youtube in the background?
When im turning on a song and its ended and youtube goes to another song, the new song goes stuttering.
I’m, using Brave on a Samsung A13
Thanks in advance
Thanks in advance
Same thing happens in my nokia 6.1 plus too
Very annoying, so far I have not found a solution, if I have I will share it with you all
Hi @Frank_85 thanks for bringing this to our attention.
Could you kindly share what version of Brave is experiencing this issue?
I have the latest 1.42.97 Also this problem is common among all versions but lately has been increased so much
Sometimes changing playback resolution from auto to 720p works but again not a solution for the problem
If you are able to, could you share a screenshot or short clip of the issue?
Also running things on 1.25x or 1.5x also does that
Thanks for sharing,
Do you experience this issue on other browsers or is this exclusively with Brave?
Also do you have any programs installed or Brave Shield settings toggled that might be interferring with the video playback?
No I don’t have any other browser that has this problem my sheild settings are default. This problem occurs mostly but not all the time
It looks like a fix around this is by disabling vulkan in brave://flags
Can you confirm if that resolves your issue?
