Annoying Vertical and Horizontal scroll bars in chatgpt page
There is an annoying horizontal and vertical bars on the chatgpt page. I tried to recreate it in the private window. Here are the images. The bars only appear in the normal mode. It is very annoying while using the chatgpt page. This issue started to appear on the latest build release of the brave browser. The version I’m using is mentioned below. Someone help me with this issue. It’s really making me mad, feels uneasy to use chatgpt. Till then, I will use chatgpt in incognito mode.
Scroll bars in an Internet browser window, are common and often expected browser behavior.
Also, you have enabled the appearance of browser settings in the lefthand sidebar.
Thank you replying me. I haven’t changed or modified the configs from the settings tab. The configs are static. This issue is occurring only since the last 2 weeks. Earlier both private tab and normal tab looked normal. No annoying horizontal and verticals bars. This is affecting only the chatgpt tab. Other tabs doesn’t have those bars in the normal mode. How to solve this?
I tried that, but it doesn’t modify the ui. Those annoying bars are still present.
Whoever faces this trouble, I somehow found a solution - download your saved passwords from brave, clear all the brave data, uninstall and re-install fresh brave. Once after I did the same, tried to open chatgpt, those annoying extra vertical bars disappeared.
Hopefully someone will find this solution to solve the same problem.
