AliExpress will not open correctly
Description of the issue: incomplete page displayed
Exact URL of the website in question: AliExpress.com
Did the issue present with default Shields settings? Yes
Does the site function as expected when Shields are turned off? Not attempted yet
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. As above …
Does the site work as expected when using Safari? Yes
Brave version (check About Brave): Latest
Apologies; disabling ad trackers allows correct opening - but is this safe?
Everything working okay?
AliExpress works well but only with the Brave Shields down! There are a few websites like that …
Try updating the lists in brave://adblock, shields up
Thank you for the advice - all now working correctly.
