Add Adguard Annoyances filter in chrome://adblock
What I see given the tools we have, it’s pretty decent. Also I noticed no nag screens if I actually logged in.
https://youtu.be/BOpQq64X4k8
I’ll check with others tomorrow, but this is what I see.
@fanboynz, I watched your testing video, but you only went to amp.reddit.com directly, which would redirect you to www.reddit.com.
I hope you can test it again, using these steps, and you will see that the popup still appears.
  1. Open this Google search result in Brave Android, with both of the Annoyances lists enabled.
    https://www.google.com/search?q=amp+reddit
  2. Click on the second search result, the AMP page that has a small AMP icon, the popup will be shown when you open it.
The popup will only be shown if it is opened by clicking on that result, if it is opened in a new tab, the popup will be blocked.
I’ll take over week or so, not the easiest to debug mobile cosmetics
It’s okay, I can wait, as long as it will be fixed at the end.
Hi @fanboynz, I just tried adding these 3 lines in brave://adblock, and it worked for me, now if I go to the same page from Google search results, the popup can be blocked.
amp-reddit-com.cdn.ampproject.org##.AppSelectorModal__body
amp-reddit-com.cdn.ampproject.org,amp.reddit.com##div[class*="AppSelectorModal"]
amp-reddit-com.cdn.ampproject.org##a[href^="https://reddit.app.link"]
Minimised the filter, but sure.
I think you still need to add amp-reddit-com.cdn.ampproject.org##.AppSelectorModal__body to block this part.
amp-reddit-com.cdn.ampproject.org,amp.reddit.com##div[class^="AppSelectorModal"] Covers this
The screenshot was taken after updating Fanboy Annoyances List to version 1.0.104 today, and that was still not blocked.
Could you try these steps to test it again?
  2. Click on the second search result, the AMP page that has a small AMP icon.
Filter updates occur every 24-48hrs.
OK, I will check again after 48 hours.
@fanboynz Thank you, now it is finally blocked.
This topic was automatically closed after 14 days. New replies are no longer allowed.
