Adblock custom filters and capturing page
Just like Vivaldi android has capturing page feature and feature for customizing adblock and tracking filters, please if possible we want to see that feature in Brave too.
Cosmetic filtering is not supported in Brave so it is necessary to do something. I know devs are trying hard but if possible add option to add custom filters like in Bromite, Vivaldi, Adblock browser by eyeoGmbh.
And sometimes page capturing is required so if possible like Vivaldi please add option to capture page.
Hello @ysl99
not sure if that available on android or not but in desktop
go to brave://adblock/ and you can add custom filter
try this in android and see if it available there
Thanks I tried but custom filter not working. Please help if it is working in your case.
you welcome but i never used it before but just a notice did you follow the syntax rule
One per line, a filter is described in Adblock Plus filter syntax
and have a nice day :slight_smile:
Yes I followed the same method but still custom filter not working. Can you help me further?
since i never used it let me ask @fanboynz to help you with that
and could you give the custom rule that did not work so he can check it and correct it if it needed
and have a nice day for both of you
https://raw.githubusercontent.com/hl2guide/All-in-One-Customized-Adblock-List/master/aio.txt
From: https://github.com/hl2guide/All-in-One-Customized-Adblock-List
I've made the final decision to deprecate this repo since it isn't achieving my expected outcomes. No more commits will be made.
We use Easylist/Easyprivacy which most of that list uses ^ Regarding the rest: https://github.com/brave/adblock-lists/issues/438
Can anyone suggest what is wrong with custom filters?
I inserted filters with adblock syntax one in one line, but they absolutely do not work. Custom filters are not currently supported?
You need to write (copy/paste) the filters, not the URL to the filters @AzagTot.
Oh, thanks for the information! Nevertheless I would like to have support for custom filters by links, hope that someday this will appearwith a normal start page (with a large set of sites). :slight_smile:
Btw, while it is not possible to add your own lists, maybe you will add these filters to the standard list?
https://easylist-downloads.adblockplus.org/cntblock.txt
https://raw.githubusercontent.com/AdguardTeam/FiltersRegistry/master/filters/filter_3_Spyware/filter.txt
https://raw.githubusercontent.com/AdguardTeam/FiltersRegistry/master/filters/filter_14_Annoyances/filter.txt
It would be cool )
