ADA Issue: Disability accessibility not available - larger tabs and menu icons
  1.  I have fine motor control problem in my hands due to rheumatoid arthritis. The tabs and menu icons are too small for my hands to click on reliably. How do I maek the m bigger? Making the fonts size bigger changs nothing in the tabs/menu.
  2. EVERYONE that uses Brave with an eye problem or hand/arm problem needs this feature because it is specific to the browser.
  3. The lack of this option means there is no disability accessibility. Why do you want to alienate those in the disability community??? Other browsers have this feature, where is this ADA feature in Brave?
For this to be amended right away.
All versions
ADA requires things like to be available. Please let me know when it will be fixed. Thank you.
A long-delayed project:
@igorrodriguez opened a new issue at GitHub:
Having worked in IT for close to 20 years, I definitely searched for a fix before adding the topic.
I was not able to find anything to fix the situation…but I did find multiple requests for the same thing.
If there is a fix then it is buried somewhere I could not find online.
