B-Rul
January 27, 2022, 11:18am
1
Ad-Block not working on pahe.li. (pop-ups and invisible ads)
https://pahe.li
Did the issue present with default Shields settings ? (yes/no)
Yes
Yes
Yes, by Blocking cookies
Yes
1.34.81
I see these pop-ups as well. Will test and forward this information to the web compat. team.
Update on the way to fix this, give it 24hrs.
B-Rul
February 2, 2022, 4:55am
4
The invicible ads are back at https://pahe.li/
Fix is incoming, give it 24-48hrs
plato
February 9, 2022, 8:32pm
6
It is still there… I tried with PiHole also, but even if I blacklist one address another appears…
B-Rul
February 26, 2022, 3:47pm
7
The popups on pahe.li are still annoying. I don’t know what happened to Brave Browser because it can’t block popups anymore, unlike Chrome it’s better to block the popups.
And for Chrome
Okay, lets see how this goes. Its only applicable on Desktop and android. (no snippets in ios unfortantly)
brave:master
← brave:fix-animepahe
opened 09:40PM - 26 Feb 22 UTC
Converted over the following filters to non-wildcard from uBO. Was repoorted in … the forums https://community.brave.app/t/ad-block-not-working-on-pahe-li/331772/7 Seems pretty active, and should be an easy win for us.
animepahe.* -> animepahe.com
mkvcage.* -> mmkvcage.site
pahe.* -> pahe.li
From the existing uBO filters:
filters-2020.txt:animepahe.*##+js(aopw, _pop)
filters-2020.txt:! rule34.paheal.net PH
filters-2020.txt:rule34.paheal.net##script[src$="ads.js"]:upward(section[id])
filters-2021.txt:pahe.ph##+js(acis, JSON.parse, break;case $.)
filters.txt:mkvcage.*,pahe.*,psarips.*##+js(aopw, _pop)
filters.txt:animepahe.com,kwik.*##^script:has-text('shift')
filters.txt:animepahe.com,kwik.*##+js(acis, String.fromCharCode, 'shift')
filters.txt:animepahe.com,kwik.*##+js(aopr, open)
filters.txt:animepahe.com,kwik.*##+js(aopr, PopAds)
filters.txt:! https://forums.lanik.us/viewtopic.php?f=62&t=44940 pahe .in / .ph
filters.txt:pahe.*##+js(acis, JSON.parse, break;case $.)
filters.txt:pahe.*##+js(aeld, , _0x)
filters.txt:@@||pahe.*^$ghide
system
Closed
March 28, 2022, 9:42pm
9
