In the Google Browser and most likely other browsers as well, they have a button in an actor’s information card (When you search their name and it shows the widget on the right hand side with information) - that button immediately shows the movies and tv shows that the actor has been in. With Brave Beta, there is no such button, you have to manually search it, and when you manually search the movies and TV shows that an actor has been in, most of the time, you have to go to a third-party website to view said shows - like Wikipedia. It’d be simpler if this could be transferred over.
Especially just trying to find something online with Brave, it doesn’t make it easy. (Look at the photos below)
BRAVE:
CHROME:
One shows the actors right away, one doesn’t. You have to specifically ask for ‘___ cast’ instead of… anything else.
Like, these are all examples. Hope there’s a revamp of the search engine ready, because sheesh:
BRAVE:
CHROME:
One shows the movies and TV, the other one shows a bunch of nonsense.
