I’d like the ability to review my site-specific shield settings. For example, maybe I temporarily disabled something for a particular uncommon workflow on a site, but forgot to turn it back on. Maybe I just want to clean up old exclusions I no longer need.
As far as I know, there’s nowhere I can see a list of all per-site shield rules. I have to visit each and every site I might have defined rules for to see if there’s a rule defined for the site. If there is a way to see this that I’m unaware of, please let me know.
Hello, above the browser you will find the BRAVE icon “lion” there you can remove the protection for that site, which does not leave protection to other sites, that option you can see in the image that is here, I hope it.
helps.
but I do not know if there is a list to exclude sites but this helps me that if I use a certain site again it is deactivated only for that
@SatoshiSquad,
I believe what @keegan is asking for is a comprehensive list somewhere that records which sites have which settings applied to them.
For example, if I have visited 3 sites, and for two of them I’ve changed my Shields settings (per-site) to Block Scripts – there should be a page/list that I can view that shows the two sites I visited along with their associated Shields settings.
Yea, I’m aware of that. But I have to visit the site I want to adjust before I can click on the Lion. What I wanted was a settings page where I could see something like
brave.com
Ads and trackers blocked = false
remotedesktop.google.com
device recognition = all device recognition allowed
inoreader.com
shields up = false
In other words, a page that lets me see all site overrides at once (and preferably be able to modify in bulk).
Would be useful to have this for the same reason it’s useful to have brave://settings/content .
In fact the link to brave://settings/content in the settings is already labeled “Site and shields settings” even though there are no Shields settings currently shown there.
I want this too. I know I want to allow shields to be off for certain sites, but that is not 25 sites. I want to pick which sites to turn the shields back on for and I can’t see the names of the sites anywhere. The only option is to clear all sites and shields and go through the process of discovering which sites I use regularly will not work without specific shield settings. It’s time consuming and aggravating and I don’t like the idea of having shields off on a ton of sites I may never visit again.
Well this is not true unless you never visit those sites again since when you do you’ll be able to tell right away that Shields are disabled as the icon will be grayed out:
Lastly, this thread is quite old and you can now see which sites you have Shields up/down for that deviate from the default settings by going to brave://settings/content/braveShields.
