a wallet problem that hasn't been fixed for years
Ekran görüntüsü 2024-10-02 213659
there is a wallet problem in the turkey region that has not been fixed for years, I am really surprised how you still cannot see such a simple problem. brave rewards is open for use in the turkey region, but the system says that uphold supports the turkey region and gemini does not, this changed years ago, uphold withdrew its support from the turkey region, while gemini now supports the turkey region. fix this problem now, you say open an account from a wallet that does not support the turkey region
I’ll leave the screenshots you need
an authorized person should take a look at this post
Hello! Sorry for the trouble you’re experiencing. Unfortunately, Turkey is listed as a region that Uphold no longer supports. So, new accounts cannot be created. More on this here: https://support.uphold.com/hc/en-us/articles/360026786712-Non-Supported-Jurisdictions
Please see the latest regarding Gemini connections. Newer connections to Gemini are not available.
https://community.brave.app/t/gemini-logged-out-and-your-request-is-still-being-processed-issue-faq/513629/2
https://support.brave.com/hc/en-us/articles/6539887971469-List-of-supported-regions-Custodial-payout-accounts
We’re working on additional Rewards support outside of custodians. You can learn more here: Please see the latest regarding Brave Rewards onchain with Solana.
Thanks again!
There seem to be different problems on the Gemini side, at least we have a chance to withdraw bat tokens, unfortunately nothing is being done at the moment.
