2 settings keep changing after restart brave and youtube issue with strict fingerprinting
1.change Trackers & ads blocking setting to aggressive
2. change Fingerprinting blocking settings to strict
3. restart brave
the setting should be kept but that did not happen it keep change back to standard for both settings
Version 1.11.97 Chromium: 84.0.4147.89 (Official Build) (64-bit)
there are another bug related to youtube when set the Fingerprinting blocking settings to strict it shows horizontal lines on Youtube videos only when the timeline scrubber is visible. When timeline scrubber is hidden the lines disappear as mentioned in this post Brave Browser Youtube Scrubber Issue by the way this user use it under windows but i am using it under linux centos 8.2
thanks for your help and have a nice day
Avoid using strict fingerprinting on youtube, was known to cause issues.
thanks for your replay but what about that 2 settings always not saved after each restart of brave other settings kept as i left them before closing brave
thanks again and have a nice day
