mx3
October 26, 2025, 7:01pm
1
Description of the issue: ZCASH Balance and transactions disappeared!!
Is the issue occurring on a specific network? Nope
What operating system are you using? Mac OS Tahoe
Brave Version (check About Brave):Brave 1.83.120 (Official Build) (arm64)
After sending two transactions shielded ZCASH into Brave Wallet the balance and transactions disappeared !!!
BUT on this Brave dev website the balance is visible: brave://wallet/dev-zcash
Please can anybody help me out?
Many thanks guys !!
Evan123
October 27, 2025, 11:47am
2
Hello! Transactions from external wallets or exchanges will not appear in the Brave Wallet. Only transactions that occur within Brave Wallet are shown in the txn history.
If you change your RPC provider for Zcash, do you see the balance reappear?
Alternative RPC Provider Option: https://zec.rocks
https://support.brave.app/hc/en-us/articles/15616019512845-Changing-the-Default-RPC-Node
mx3
October 27, 2025, 12:21pm
3
Hey Evan123
Thanks for your answer. But unfortunately nothing changed. I still cant see balance or transactions.
BUT as I say I can see the balance here: brave://wallet/dev-zcash
Regards
Evan123
October 27, 2025, 12:22pm
4
To clarify, you will not see the transactions since they did not take place in the Brave Wallet.
Please also make sure your Shielded account is fully synced.
mx3
October 27, 2025, 1:04pm
5
It is fully synced and zero blocks behind.
