i useing youtube on brave in mobile mode i recently bought yt premium but what i see is i can’t able to see premium quality on moblie mode why and how to fix it?
Please edit your Original Post (“OP”) above, in order to include:
- Brave Browser version numbers
- Android OS version number
- Android device model info
According to Brave Search (Answer with AI):
The limitation is likely due to YouTube enforcing mobile quality caps on third-party browsers or Brave’s content filters interfering with high-resolution streams.
YouTube Mobile Cap: YouTube often restricts video quality to 720p or lower on mobile web browsers, regardless of Premium status, to drive app subscriptions.
Content Filter Interference: Brave’s ad-blocking filters can sometimes prevent high-quality video tracks from loading.
Resolution Check: If the issue persists, ensure your Brave browser is updated and try manually selecting the highest available resolution in the settings menu.
Workaround: Switching the browser to Desktop mode (via the three-dot menu) may allow access to higher resolutions like 1080p or 4K, as YouTube treats the mobile site differently.
Update Filters: Go to Settings > Shields & Privacy > Content Filtering and tap Update to ensure your ad-block lists are current, as outdated filters can cause playback issues.
(AI-generated answer. Please verify critical facts.)
