It’s working in private but not on normal maybe they’re capturing data through logged in accounts or something and trying to stop ad-blocking through that.
You have to clear cookie for youtube and google if you use google as login to youtube.
Note that the clearing cookies/site data route does not work for everyone.
Thank you so much. I tried a lot of things but this worked.
You don’t need to remove all cookies, just the youtube and google ones, in which case you’d only have 2 sites to log back into. However, if you use a separate profile for Google sites, you have more freedom over the extensions you can use in your main profile, and when you need to clear out Google cookies it’s much easier to set everything up again.
It also makes it harder for them to track you.
You could use a separate profile just for youtube if that’s less inconvenient.
UPDATE: the only thing that worked for me was to uninstall (deleting all navigation data)/re-install Brave.
Make sure to make a backup for saved passwords and bookmarks beforehand (which I didn’t and I regretted it).
We have an official fix in for this:
