XFINITY using Adobe Flash
When starting the Xfinity TVToGo selection it requires Adobe Flash to be running. When the channel attempts to load you consistently get an error asking to allow Flash to run.
I have reset the parameter multiple times and have cleared cache and reset again.
https://www.xfinity.com/stream/live/Watch-NBC-Bay-Area-News-at-5/7728061817102576105/DKNTV
Did the issue present with default Shields settings? (yes/no) Yes
Does the site function as expected when Shields are turned off? NO
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): NO
Does the site work as expected when using Chrome? YES
Brave version (check About Brave): 1.1.23
Yeah, existing issue regarding Xfinity.
