I’ll attach a screenshot, where it refuses to update my Widevine bc of which I can’t view Netflix or Prime. And no, I’m not getting the auto download pop up from EITHER side of the search bar. I tried. In fact, most of the auto updates seem broken. (The dictionary update doesn’t work, which now means auto-spell check doesn’t work either.)
Here are the sites I looked for help. NONE of these solutions worked since at its core, the Widevine update option is broken.
Link 1 Link 2 Link 3
Now, I am technologically challenged, so if someone knows a solution to this, please do explain in easy terms!
Brave:
Version 1.17.75 Chromium: 87.0.4280.88 (Official Build) (64-bit)
Windows: 10, 64-bit
