Why my Developer Tools > Network > XHR preview frame became small
Does anyone have a solution for this, i got my network preview frame became small and not fit to the bigger frame? Thanks
Brave version: Brave 1.79.118 (Official Build) (64-bit)
@dhnstr
My Brave Browser > Developer Tools window for your Brave Community issue/webpage - examine the settings, by clicking on the gear icons and also on the vertical-3-dot icon along the right edge of the window. For example, the vertical-3-dot icon click, will reveal a pop-down menu showing: “Hide console drawer” or “Show console drawer”:
thanks for the info, but the main problem is on the preview. before this problem came the frame on the preview work perfectly not minimize like now
@dhnstr
Your XHR preview and response issue, may be a Chromium > Blink issue.
@Mattches of Brave Support, may know whomever at Brave, knows that the issue is one to be considered by Brave or by Chromium.
Ref. material - another old XHR preview issue at Chromium:
https://issues.chromium.org/issues/40165581
@Mattches
OP getting a lot of views. A link, that I provided above, quickly went past 50 clicks.
Yeah this looks like an upstream Chromium issue. Looks the same way in Chrome:
(Chrome)
(Brave)
Looks like other users are experiencing this as well:
I will let the team know but it will likely need to wait for an upstream fix.
