Description of the issue: When on Twitch.com and watching a broadcast, clicking the clip button brings you to a new page where you can make your clip, but it will be muted. Sound is often important to clips so this should be corrected.
- Go to Twitch.com (you’ll need an account)
- Go to a live broadcast channel
- Click the clip button and you’ll be taken to a new page where a clip is there to edit and publish, but you won’t have any sound.
Expected result: When making a clip, there should be audio. The video window even has a volume meter, but it’ll be turned all the way up and it’ll be ‘muted.’
Brave Version( check About Brave): v1.63.169
Additional Information: This started maybe a month ago. I don’t have any extensions that affect volume.
