Weird hitbox issues
  1. Download latest version of brave
  2. Go to a website with this problem (etc youtube.com)
  3. Hitboxes don’t work
Expected result: In the top left corner, the youtube logo normally goes to homepage, but after the update, you can only click the small red logo and not the text, it applies to some other buttons like Twitch inbox, but I couldn’t find any more
Brave Version( check About Brave): v1.89.132, Macbook Pro M1 2020
Additional Information: Its very niche, I tried in safari and it works.
the youtube logo here can only go to homepage if you click the red part, not the text like before update.
I have observed the same issue please fix this issue asap
I feel this issue is similar to this issue I have reported - Unable to left click on text boxes
@alxwuz not seeing this issue on my end, also on macOS. The Youtube logo is clickable as it has always been and will land me on the homepage. First, can you please try:
  1. Launch Brave
  2. Click Menu > More tools > Guest profile
  3. Close your original profile window
  4. Login to youtube or any other site where you see this issue in the guest window
  5. Test to see if you see the same behavior there
I’m also experiencing something similar. From what I can tell its site agnostic and almost like a portion of the upper left first 60 pixels is “dead” and un-interactable where most sites have a search bar or menu options. On Brave 1.89.132 arm64
It is the same, wether on incog or a new profile.
gmail, youtube, rumble… Have to very carefully click on every website logo to return to their homepage.
I think this is actually the same issue as described here:
Should get a fix in the next update.
Search bar of gmail also needs to be clicked carefully. Hopefully, it is the same issue.
Can we make the release process faster for this issue. Most of the websites are unusable because of this issue. Atleast release in the nightly version the fix is already in.
I agree, after new update bug is still not fixed.
1.89.137 Chromium: 147.0.7727.102 (Official Build) (arm64)
still same bug.
