Websites stuck on loading screen and fail to open
I am completely unable to open or load any website using the Brave app on my Android device. Every time I try to browse, the page gets stuck indefinitely on the loading screen. I have already tried clearing the app cache, but it did not resolve the issue.
​How can this issue be reproduced?
  1. ​Open the Brave Browser app on the Android device.
  2. ​Type any URL or search query into the address bar and press enter.
  3. ​The page attempts to load but remains permanently stuck on the loading indicator, failing to render any content.
​Expected result:
Websites should load successfully and display their content properly, as they do on a functional browser.
​Brave Version( check About Brave):
Brave 1.91.175, Chromium 149.0.7827.155
​Mobile Device details
Vivo Z1 Pro Android 11
​Additional Information:
  • ​The issue persists even after performing a “Clear Cache” in the application settings.
  • ​Internet connection is stable. I have tested other browsers, specifically Google Chrome, and they are working perfectly normal on the same device and network.
Can you fully uninstall (not just clear cache) and reinstall Brave on Android and see if your problem is resolved?
I’m having the same issues since the most recent update. Reinstall and clearing all data and cache has done nothing. Loads fine in other browsers. I will likely just have to switch apps.
I already switch browser to cromite its really similar to brave. I will check again on brave if they have a new update to fix it
I’m having the same issue with Brave (Release/Main version) on one of my older android phones, but not the other, newer one. Issue started two updates ago around last Thurs I think. Was working perfectly fine until I updated. Now it’ll launch but I can’t see my BAT balance or load any sites. There was a further update on Sat I think, but it made no difference.
Still not fixed on latest update
@CaptainYoshii , @Arnasa2 , @Thrive
Brave Support will probably need complete Android mobile device details.
cc: @Mattches
@289wk it’s same with my issue, just waiting for update.
@gabriel.dim
If anyone here is experiencing the issue OP is, please share the specific Brave version, Android version and device model with us here.
Note: I can fix it temporarily by force closing Brave. But then it comes back, with no clear trigger event.
No websites render, just white screen. The tab previews do show. When activating a tab the site content shows briefly, then goes white.
Brave 1.91.180, Chromium 149.0.7827.201
Android 16; Build/CP1A.260405.005
Pixel 6
@Mattches
