Waiting for extension PDF Viewer... ...forever!
Since starting Brave this morning every page I try to load is blocked, spinners are spinning and in the down left corner it says “Waiting for extension PDF Viewer…”.
This happens whenever I try to load a url in any tab. From previously opened from my last session, to new tabs. The new tab loads with out a problem, the one by brave which gives me stats of how awesome it is, anything I load after that has the same issue.
Restarting the browser has no effect.
I had to use Chrome to post this :frowning:
Just load any url in any tab.
That brave doesn+t wait for PDF Viewer on pages without it!?
Just started today and its constant.
MacOS 10.14.4
Brave Version 0.64.75 Chromium: 74.0.3729.131 (Official Build) (64-bit)
Is there a way to disable PDF Viewer temporarily?
By going to the address in the picture above. Settings>Site Settings>PDF Documents
Then switching Download PDF on and off fixed the problem.
