Volume Master Extension
Volume Master Extension Problems the same bug came on the new version of brave
I’m not seeing this issue on my end. It looks like this extension controls the volume level per tab. So if you change the volume in one tab it won’t change it for the other – even if I refresh that tab, the volume master extension stays at the selected volume for that tab.
Can you please provide the exact steps to produce the error you’re seeing on your end?
am experiencing the exact issue on the link i posted
Yes, and in that post you also did not include the steps to reproduce the issue. The reason these are included is so that we can make sure that we are seeing and doing exactly what you’re seeing on your end.
Because right now this extension appears to work perfectly fine for me. I tested on both Windows 11 and macOS systems, in and in Brave Nightly, Beta and stable builds and they all appear to work without issue. So either I’m performing the wrong steps or I am not fully understanding the issue you’re encountering. Either way I need more information.
If you can provide the exact steps you’re taking so that I can try to reproduce this issue – or you can share a short screen recording of the issue – I’d be more than happy to troubleshoot this with you.
there is the same issue I had on January on that first link
Do you see this behavior when using the extension in other browsers?
I only have one curently cause brave just blocks ads more effective than others but tried on brave beta, nightly still the same thing
It would be a helpful test, if you wouldn’t mind briefly installing one and testing the behavior. Also, I’m assuming you’ve tried this without any other extensions enabled/installed – is that correct?
Here is what I see when I perform this test. I’ve left the default at 100% and set the sites tab to 300% – after ~30s of opening/closing the extension panel, volume never gets reset:
i can’t upload a long one cause brave needs 10MB of videos
not yet but am adding a new brave profile and install volume master and see if the issue is my extensions.
here is a new brave profile with nothing on it just the volume master extension
I suspect this might be a Chromium issue – although if that was the case I’d also expect to be able to reproduce it. I’ve asked a couple other team members to see if they can try on their end.
