Volume Master Extension Problems
Volume Master Bug started after brave beta v1.87.118
the first pic is at 300%
and another one
the third one is the bug that keeps resetting the volume master
the same bug occurs after I download all brave versions with fresh user data and i go to web store and add volume master then I test if it will reset the volume. or go to a random website and open volume master and set it to 8% now right click the extension several times and it will reset back to 100%
Windows 10 Pro 22h2 OS build 19045.6809, brave stable v1.86.139, brave beta v1.87.165, and brave Nightly v1.88.33
Additional Information: the issue does not appear on google chrome
the new brave stable update 1.86.142 fixed the issue
