Vertical tabs with grey theme uses wrong color for selected tab
  1. Use Grey Theme In Brave Appearance
  2. Vertical tabs
Expected result: Like Horizontal tabs, the selected tab should be gray.
Brave Version( check About Brave):1.93.138
You’re referring to this “gray” theme?
As you can see in the image, the tab selection appears to be using the correct color. In the title you specifically state vertical tabs – if you switch to the standard/horizontal tabs do you see the same color for selected tabs?
this is the grey theme in horizontal tabs its right.
Do you happen to have any custom theming enabled in Windows itself? I’m wondering if it’s picking this color up from somewhere else.
If you were to open a Private browsing window, does the selected tab color appear “orange” there as well?
no nothing like that i am 90 pct sure its a brave browser issue cause few updates ago it was working right. i have grey color accent in windows as well so no.
Can you check the other part of my message as well?
Nothing as such
Do you have any extensions installed in the browser at this time? Additionally, if you create a new browser profile (Menu > More tools > Add profile), close your original profile, then set the new prof. to use vertical tabs, do you see the same issue there?
