Using bitdefender extensions
Is there a way to use/install Bitdefender extensions in Brave? I LOVE the browers, but need access to these extensions. So I temporarily went back to Edge. Sigh.
should this be posted somewhere else. I cannot see another option. Finding this was difficult.
Hello @HughL
if the extension in the google webstore then you can install it or add the extension directly if you have it
not sure if you get error or i miss something
There is no option to install it. I was wondering if there is a work around since it IS available for Edge (which I have), Chrome (which I temporarily loaded), and Firefox (which I have NOT reinstalled).
how you add it to chrome or edge?
brave and edge based on chrome so any extension work for chrome work for other
Look for a list of extensions, and then add it.
The option did not appear in Brave.
Lets see if that works, reply if it does
Sorry. I see the anti-tracker. I wanted access to their Password Manager (it has some features I find better than Brave’s wallet.
Sorry I was unclear.
Hugh
Hugh LaFollette
hnc@theinternetemail.com
how you add it to chrome?
if it not in the web store where the extension come from if you have the file then you can install it
Bitwarden is miles better and universally praised.
